tommy24a
Aug 23, 2020Explorer
Strange issue
AC started to act up. 2006 Fleetwood Wilderness 5th wheel. The thermostat is marked as a RVP. Its a single stage for heat and cool. Purchased a honeywell RTH111b stat. Did some research on the wiring. At first the high fan came on. Unhooked the stat to make sure wiring was not loose. Put it back on. Nothing going on now. Took off again and tried to jumper the fan. Nothing
Waited a cpl hours and now was able to start high fan. Tried to now jumper the compressor..shuts fan off. Does not start compressor. Tried to jumper high fan again..nothing
Waited a cpl hours and jumped fan again and working. Not sure what the check is going on.
