sansouci2's avatar
sansouci2
Strange Problem
We have a 2003 40 foot Monaco Executive with a strange problem. Cold in Mn. After a cold 28 Degree night I put out one of three slides. Then I checked the water pump, it was not working. Went to put another slide out and it is not working along with the backup camera and with a few other things. Went to the circuit breakers and they were fine. Eventually unplugged the shore power and ceiling lights worked so I knew it was not a house battery problem. Plugged the shore power back on and reset the breakers. All worked. When I tried the water pump again the same thing happened. Reset breakers, nothing. Discontinued shore power, everything work, except I did not try water pump. Plugged shore power in and slides, backup camera work still work. What would be the connection with the water pump and the slides ect??
The Wife
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
