fm8042's avatar
fm8042
Suburban SF-30F Furnace
My furnace will cycle normally for a few cycles and then will not operate when heat is called for. I have replaced the circuit boards in the furnace and the ceiling A/C unit, I have cleaned the sail switch, and replaced the limit switch and thermostat. It does this on battery or shore power. I can hear the relay in the A/C unit click on when the thermostat calls for heat, but the fan does not even cycle on. Any ideas on what else I might check?
  • I don't know my model number of my suburban but we also bought and replaced and cleaned up heater and it turned out to be only a loose connection several years ago. Found it by wiggling wires. Took some time. Wiggled one wire out of many and then heard a "click" on one wire. Removed that wire connection and it was rusty, cleaned and it worked right after that for about 3 months and did it again. Turns out that connection was also rusty inside the motor. Cleaned it up (actually RV guy took motor apart and cleaned up connections inside motor) and no problems since. Took a long time to find. First time thru was quick to check wires, second time thru, checking wires and use volt meter to make sure elec was making it to connection took a lot longer to wait for system to get into right operating step. I was able to use a paper clip to "jump" 12 volt and put a meter on it. Hope this helps, I'm not a elec guy but I can tell if something has a connection or not. It would also be nice to have a troubling shooting guide or owners manual handy. Not sure if link will work or not I just googled it up.
    http://www.brwholesale.com/itemNotes/schematics/Suburban/Furnaces/Furnace_Service_Manual.pdf
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
