โApr-17-2014 05:50 AM
โApr-17-2014 07:21 AM
wrgrs50s wrote:
Check for spider webs or dirt dobber nest in the burner tube. That will make it blow back like that. It may need a good cleaning.
โApr-17-2014 07:20 AM
โApr-17-2014 07:17 AM
โApr-17-2014 06:08 AM
GASMAN6674 wrote:
Get a manual and check pilot posistion to the burner against the spec's and while you are at it clean the burner. What you are having is called delayed ingnition and can cause you to lose your eyebrows ๐
Good Luck
โApr-17-2014 05:59 AM
