laplatarosa's avatar
laplatarosa
Surge Guard Plus Model 40250-RVC
I have a large DP with and installed Surge Guard Plus Model 40250-RVC Automatic Transfer Switch with RV Power Protection 120/250V 50A, 60Hz.
The coach does not want to hook-up to a 50amp , receptacle that is showing L1 - 124v, L2 - 127v, LI to ground & to neutral - 124v, L2 to ground and to neutral - 127v. L1 to L2 - 252v.
The generator connects and works fine. Also the auto Genset start works as designed.
I CAN connect to a 30 amp receptacle via a dog-bone adapter at the receptacle on the L1 -124v side of the pedestal.
The specs for the Surge Guard say below 132v range is OK.
Any ideas why I cannot connect to the 50amp power.
I'm using the same power cord for all connections.
Thanks in advance for all ideas.
LaPlataRosa
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
