KcBorne
May 21, 2013Explorer
Surge Protector didn't work?
A couple of weeks back my AC and DC power killed simultaneously, and i had been trying to figure out the problem. I was getting 125v at all the breakers, but still no power. I finally opened my Progressive Industries Model EMS-HW30C surge protector, and the green wire had burnt completely in half on the line going IN the unit. My power converter also got fried when all this happened. The people at Progressive said the converter looked like it had been plugged into a 220v line.
I cut/cleaned/re-installed the wire and i got my AC power back on, and I received a new PD 4655 55 amp converter replacement, but i want to understand why my surge protector didn't stop the surge from damaging my equipment? I'm hesitant to install this new 220$ converter without adequate protection.
My surge protector was bypassed at the time that the surge happened because the computing system in the EMS unit was having problems(continuous previous error code), but the manual says regarding a Bypass: "This switch is located on the remote panel, and allows the user to bypass the computer circuit in the EMS in the event of computer failure, thus allowing AC power into the RV. This does not disable the surge protection portion of the EMS; however, all other features are disabled."
If the surge protection isn't disabled in a bypass, why did the surge fry my converter? Any help is appreciated.
