SteveAE's avatar
SteveAE
Tank Heater vs.Recirculating Hot Water
Has anyone tried recirculating hot water into their freshwater tank as an alternative to using a tank heater? How did it work? Issues? Comments from those who haven't done this are also welcome.
I know that smkettner did an excellent write up awhile back about recirculating hot water in his RV plumbing but I don't believe it included the freshwater tank as part of the loop.
If I did the conversions right, 5 gallons of hot water (120 degrees) per hour into 40 degree tank water would be about equivalent to having a 1KW tank heater mounted inside the tank. I don't know the power consumption of electric tank heaters, but suspect it isn't much more than this (and they are mounted outside the tank as well).
Steve
