Temporary fix of previous posted air vent problem
n3or
Temporarily repaired vent problem. Could not find any auto supply store that sold the small tubing. Thought about using the end of a ball point ink refill to splice the two ends, however, the tubing was the same size. Finally bought some 1/8 inch shrink tubing, put over the tube, held the two ends as tight together as I could, and heated the tubing to shrink it. Removed one of the ducts behind the glove box and tried the vent button. Vent opened and closed properly. I KNOW this is only a temporary fix, BUT, I wanted to thank all of you for your help. N3OR
2 REPLIES 2
Fleetwood99
price check and availablilly we use http://www.mcmaster.com/#
99 Fleetwood Vision 36Zulu V10 Gas F53 Chassis
Hyd Leveling man/keypad (Powergear)
Electric Slideouts (Powergear) x2
2005' 4020 Fadal 4Axis CNC Mill w/24Datc
Hendy 16x72" WWII Navy Lathe 1800RPM
pianotuna
Nomad III
Nomad III
Hi,
Try a hobby shop for small tubing.
Regards, Don
