n3or's avatar
n3or
Temporary fix of previous posted air vent problem
Temporarily repaired vent problem. Could not find any auto supply store that sold the small tubing. Thought about using the end of a ball point ink refill to splice the two ends, however, the tubing was the same size. Finally bought some 1/8 inch shrink tubing, put over the tube, held the two ends as tight together as I could, and heated the tubing to shrink it. Removed one of the ducts behind the glove box and tried the vent button. Vent opened and closed properly. I KNOW this is only a temporary fix, BUT, I wanted to thank all of you for your help. N3OR
