CA_Traveler
Oct 25, 2021Explorer III
rickhise wrote:Yes but be aware that there is often long and smaller gauge wires to the RV which will lower the voltage.JaxDad wrote:
Set the voltmeter to DC volts, neg to neg, pos to pos and you should see about 14.5 volts if it’s charging, 12 volts if not charging.
Thanks simple enough.
I’m assuming I could do the same thing to check if
Truck running an power cord for brakes and lights
Is charging as well??
A better check is to measure both amps and voltage. I have a DC clampon ampmeter that is simple to use and also measures voltage.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
