Naio's avatar
Naio
Jun 03, 2016
Testing AGM batteries?
When I got my last set of batteries (150aH AGM, used), they had been tested on a high-amp car tester. But my friend who knows batteries pretty well said that was not a proper test, that what we should do was put a 25 amp load on, and see how long the battery took to get down to 11v or so.
This method caused us to reject several batteries that had tested fine on the high amp tester. And the batteries I got have been good.
This same friend, though, told me it was important to cycle batteries in long term storage (not just float them). Doing that, with the 25 amp load, one got away from me, suddenly dropped to 10.5v or so, and that killed it.
I have also killed numerous 33aH batteries by putting a 100amp brief load on them, before I figured out that was not cool.
So. How should I test these used AGMs I am looking at now? Should I rely on the sellers 150aH 15-second test? Should I do a smaller load for longer? What do you all do?
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
