groundhogy's avatar
groundhogy
The black wire on my plug is burnt up...
So after the winter, I pulled up and moved.
I was using the 50A socket with the 50-30 adapter.
One of my connections was burnt up and the plastic was melted.
The flat prong was black.
The part that plugs into the pedestal was ok. That part was also shielded from weather.
The 50-30 adapter part is about 12" long.
The 50 side was ok as mentioned above. The problem was on the 30 side, which was in the weather.
The black wire terminal was the one that was burnt up.
Anybody have insight on causes here?
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 16, 2026
