TomG2's avatar
TomG2
Thermal Glue Application
The spring clip that holds the thermostat to the tank on my water heater is failing. Would thermal glue work to hold it in place and what brand would you recommend?
1 Reply
  • Can't help you so why not try.
    I have used J.B. Weld on many applications needing to attach metal pieces to each other.
    Good Luck
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
