Thermostat
64thunderbolt
which digital thermostat would be compatable with my 2004 Coleman Mach a/c & propane furnace? My old mech one has drastic swings. Found one on Amazon #8330-3362 but don't want to buy till I know it will work. Thanks for any tips provided.
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
11 REPLIES 11
Dave_H_M
which ever one you get, go for the illuminated face when you are using it. I learned the hard way bout fumbling around in the dark. The illuminated face when used is the cat's meow.
Old-Biscuit
64thunderbolt wrote:
Thanks Old-Biscuit, what is wrong with the one I linked. It said wire color is matched to the old one?
Nothing wrong with the Coleman Mach Digital except the price!
$25 for Hunter available at Walmart/ACE Hardware/Lowes etc.
Or $50---$70 for the Coleman via Amazon etc. plus shipping
I like items that work and are low cost
64thunderbolt
Glen
Truma tankless WH
2011 RZR 900xp
Old-Biscuit
Coleman Mach to Hunter Instructions
Durotherm to Hunter
64thunderbolt
this is the one I found.http://ecx.images-amazon.com/images/I/31j7kUCH4yL.jpg
Glen
Truma tankless WH
2011 RZR 900xp
dieseltruckdriv
I installed a Honeywell programmable in my 5er. The same one I have at home. I only wired the AC fan on high. I can't see using low if I need AC. But I like it cooler.
I have it set pretty cool at night, but warming up before we get out of bed in the morning.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
Sfla2
Hunter 42999B found mine on AMZ, also` look at utube for video
98 Coachmen "C" Santara Model FL (Front Lounge) 30.4
Ford V 10 Super Duty (same as E 450)
BFL13
Similar anyway. The old type Duotherms will be hard to find in future, so will be forced to get the digital kit eventually I suppose. Could be the same with the old style Colemans, no idea.
Perhaps there is something about it on their website.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
donn0128
Hunter Douglas for about 25 dollars at WalMart. The battery powered one is a great upgrade on the cheap. I understand there is also a Lux model that is powered by a couple of AA batteries. There are instructions all over the internet for connecting the HD version. Be sure to also pick up a mini SPST toggle switch for around 3 dollars at Radio Shack to allow the AC two speed fan feature.
64thunderbolt
Thanks. I will pass on that. I have been using the old ones for 16+ years so I suppose I can continue for a few more.
Mine is a Coleman Mach. Is that the same as duotherm?
Glen
Truma tankless WH
2011 RZR 900xp
BFL13
For the Duotherm old ones, the replacement involves putting a digital "kit" up in the air conditioner to go with the new type thermostat. About $150 just for the parts.
Photo in Profile
