They say 10 amps maximum, but....
landyacht318
But what if it Could do 480 watts at 14.7vDC? Perhaps all it needs it the required ventilation.
Who will be the guinea pig?
DROK Adjustable DC Power Voltage Converter AC 110V-220V to DC 0-48V Module Switching Power Supply
Notice the nice easy to access potentiometer and voltmeter.
19 REPLIES 19
time2roll
Will it allow voltage to sag to limit the amps or does it blow a fuse?
wa8yxm
Yes DC supplies can be stacked in parallel however you must set the voltage EXACTLY on them and that kind of precision is hard even in an electronics lab.
If it says 10 amps max. Odds are trying to suck 20 is going to prove the truth of one of Murphy's Laws
A 25 dollar Transistor will blow to protect a 25 cent fuse..
Only today, the prices have gone up.
MEXICOWANDERER
This critter
WILL meaning YES
Equalize up to a series pair of GC 220 golf car batteries or better yet one battery at a time. Group 24 27 29 31 flooded.
MEXICOWANDERER
YOU
YOU
YOU
BUDGET RUINER
YOU!
brulaz
US$33 for 480W adjustable 0-48V power supply?
But is it limited to 10A at lower voltages as well?
"maximum output current is 10A, so this item will not fit for your device with over 10A current."
Sort of sounds like it's limited to 10A, period.
I just spent a lot more than that for a 500W Meanwell 24-32V
without the readout and nice knob. But it can definitely do 18.6A at its rated 27V.
Maybe the DROK can be stacked in parallel.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
