nschick's avatar
nschick
Ticking noise under fridge
I have a ticking noise coming from under my fridge and can't figure out what it is. It seems sporadic but is driving my nuts at night.
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
  • Almot's avatar
    Almot
    When fridge works as it should, igniter takes about one second to fire up. Then you hear the "whoosh" sound of the fire. Then it will click again in about one hour.
    It is not loud in my 6cf Norcold, can barely hear it when standing next to the fridge. If fridge is close to the bed, this can get annoying in the night. 110V compressor fridge makes more noises of all kind.
  • JeremyFr wrote:
    The igniter firing for the burner on the fridge? Mine makes a "ticking" noise when it fires.
    This^^^^
  • The igniter firing for the burner on the fridge? Mine makes a "ticking" noise when it fires.
  • Well are you sure its the fridge. A lot of builders put converters under the fridge.
  • What kind / brand of fridge? Gas / Electric ? Constant ticking or time to time? Could it be a metal expansion type ticking from the burning heating up?
