Tioga Won't Budge after long neglect. Help, please.
211Racing
Wife did something sweet but silly to help out a friend. Bought her 2002 Tioga 24d. Base is a Ford e350 Super Duty van. Apparently it has not been started or moved in over a year. (I'll post about my starting questions in another post.) Here I'd like to know why it won't budge. It will run for a few brief seconds on starting fluid, when I get it into neutral. Today I did put a tow strap between the RV and my 4Runner to try to move the RV a little before the tow truck comes tomorrow. Pulled gently until the T4R wheels spun. RV was unmoved. What am I looking at? The parking brake did not seem to be engaged, but was very stiff until I worked the pedal and then the release several dozen times. Do the brakes rust/freeze-shut on these things? Do I need to get it running somehow (fuel directly into fuel rail) to bring it to life? Would really like to have a game plan before the tow shows up. Thank you in advance for sharing your knowledge.
36 REPLIES 36
ksg5000
DancinCampers wrote:
My 2006 Jeep Liberty, 4 wheel disc brakes, had shoes in the rear drum assembly for parking brake. Sometimes reversing direction will free drum brakes.
I second that - doesn't cost anything and might work.
Kevin
DancinCampers
Dan & Sharon (Kasey, Our Yorkie, RIP 9Jan'05-26Jul'17)
2012 Winnebago Journey 36M
2020 Chevy Equinox, Blue Ox Aventa II, Air Force One
If You Obey All The Rules, You Miss All The Fun
wa8yxm
Beverley&Ken wrote:
There's a good possibility that your brakes are 'seized' or badly rusted. Service brakes or parking brake. You may have released the parking brake pedal, but the actual brake may still be on. Also the service brake rotors, pads could be badly rusted.
The extra power and traction from the tow truck may be enough to free them up to be towed. When you get it home, time for a good inspection of all.
Ken
I will double that Now if the "Service" Brakes are disc type they are likely ok but the parking brake is likely a drum type on the drive shaft just aft of the transmission... That's where I'd start.
dodge_guy
If the brakes are rusted after sitting for a year, Iโ€™d hate to know what else is that badly rusted under there!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Oregun
Parking brakes will sometimes freeze up if they sit for long period of time. Maybe the gas in the tank has gone stale.
Beverley_Ken
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Lwiddis
Lift a wheel. Will it spin? Repeat all four corners. Block your wheels carefully!
