DrewE
Jun 14, 2017Explorer II
As others have said, it doesn't make much difference in terms of pressure changes unless the temperature is changing wildly overnight.
If one (or more) of the tires are quite low, I think it would be a good idea to double-check them before leaving in case there is a slow leak. If they're all relatively close to the correct pressure and all about the same, it's a pretty good guess that none are leaking and that they won't develop a leak sitting parked overnight.
