- CapriRacerExplorer II
JimK-NY wrote:
..... BTW, did you encounter any data about the age of tires? .....
Yes, but nothing useful for the consumer.
But if this project was about trying to determine when tires should be removed from service due to age, there are a number of problems:
Ambient temperature plays a HUGE!! role in this. Tires in Phoenix behave differently than tires in Minneapolis. Those of us in the tire industry have the data that says that most tire failures occurs in (and in pretty much this order) AZ, CA, TX, NV, and FL.
FL seems the odd man out, but if you compare the temperature profile of FL over the span of a year, it is fairly flat but elevated. The net heat input to the tire is pretty high compared to - say - MN. - JimK-NYExplorer IICapriRacer, thanks. That is interesting information. BTW, did you encounter any data about the age of tires? I have seen my RV tires, dry rot pretty quickly. I suppose part of that is intermittent use that is not good for tires. I had a badly cracked and dry rotted spare that had been under my RV for 4 years. I just had to replace 2 more tires that were 5 years old and only had about half of the tread wear. For RVs I suspect a lot of tire issues are due to age instead of load or wear.
- CapriRacerExplorer IIAllow me to tell what I know about the 15% reserve capacity.
Remember the Ford/Firestone controversy some years back? Shortly after the recall was announced, the Feds turned their attention to the rest of the industry and asked some very probing questions. The company I worked for had a large database of tire returns. I was one of the guys who did the data analysis - and among the things we discovered was that the greater the reserve capacity, the fewer the tire failures - and 15% seemed to be the point where no failures were reported.
We adopted the stance that, in the OE market, we would not supply tires to any vehicle that didn't have a 15% reserve capacity. When we announced that to Ford, GM, Toyota, etc., their response was that other tire manufacturers had found similar things, and that they were taking that under consideration - which they (the vehicle manufacturers) by and large did. Today you will find that the GAWRS for their pickups and SUV's are at about 85% of the load carrying capacity of the tires at the pressure specified. This started about 2008.
That's where I think that 15% came from. I also think trailer manufacturers - who weren't subjected to the intense strutiny in that time frame - didn't pick up on the message. Certainly, there is a disconnect between the tire manufacturers and the trailer manufacturers, unlike car and truck manfacturers. - myredracerExplorer II
JimK-NY wrote:
myredracer wrote:
......This is important and you want at least 15 percent capacity and more is better. Running on psi lower than the max. sidewall rating will reduce the reserve capacity and can result in premature tire failure.
According to my Firestone dealer, LT tires are load rated so that they are considered safe at 100 percent of the load rating for the life of the tire.
Where did you come up with the 15 percent number? I did not see it on the webpage you linked.
See the index on the left side of his blog and read through his posts on reserve load capacity. I'll trust what Roger Marble says over a tire dealer any day. - JimK-NYExplorer II
Where did you come up with the 15 percent number? I did not see it on the webpage you linked. - myredracerExplorer IISet the cold inflation pressure to the max. sidewall psi after all tires have been in the shade and not in use for at least 2 hours (3 is better). "Cold" is the ambient temp. in the immediate area of the tires. Day of trip or day before, won't really matter. Sometimes it's not possible to have your camper in the shade later in the day so either the evening before or early morning of the trip is fine to set the CIP.
Remember, always follow the 3 golden rules for ST type tires (if that's what you have): never tow (1) under-inflated, (2) overloaded & (3) over the max speed rating of the tire (usually 65 mph for ST). Sadly, neither the dealer or RV manufacturer tell you this and there really ought to be a sticker on the exterior right above the wheels with the pertinent info.
If you haven't yet, it's good practice to go to a scale and find what the weight on the axles/tires is, and side to side can also be a good idea for a trailer with a heavy slide on one side. The weight will give you the amount of "reserve load capacity" you have in the tires. This is important and you want at least 15 percent capacity and more is better. Running on psi lower than the max. sidewall rating will reduce the reserve capacity and can result in premature tire failure.
Anything and everything you ever want to know about RV tires can be found on RVtiresafety.net by a retired tire engineer. Lotsa great bedtime reading for camping. :) - jadatisExplorerStated already that the rubber of tire must stay below a sertain temperature, but what is that temperature?
I dont know either, but the man from Vredestein told me that the tires are "backed" at 170 degr C /338 degr F?. This sets the sulfurbridges at that rate that the rubber is flexible but not hard.
My suspicion is that this hardening already begins at lower temp.
So as long as I did not hear it for shure , I will keep it at 130 gr C /266 degr F?.
Then if we calculate with this, and say that higher temp differences give more heatransfer, its lineair.
So example : outside ( O) temp 65degr F, Inside tire temp ( I) 115 degrF, hottest part of rubber ( R) 265 degr F.
Then temp difference R/O 200 degr F and R/I 150 degr F.
Now new situation O= 90 degr F, I = 140 degr F, R must stay below 265 degr F.
Then temp differences , R/O=175 degr F , R/I= 125 degr F.
Then differences between situations.
R/O 175/200=85% of heat-energy possible to transport in new situation then in old.
R/I 125/150=83% transport possible per second in new then old.
Now I state that for instance half of deflection gives half of heatproduction a cycle, so also linear.
So roughly the tire must produce 84% of heatenergy in new situation the old , and so must have only 84% of the deflection in new then old situation. Then heatproduction is in balance with Cooling down of rubber, so rubber reaches in new situation also 265 degr F.
Now its gets even more complicated, howmuch lesser deflection does the tire get in new situation versus old. Lesser deflection gives lesser heatprocuction, and when constant temps in and out tire and rubber, the heating up and cooling down is in balance.
We could calculate the loadcapacity for the new pressure , wich would give again a ratio between old and new surface on the ground, and you could determine the new deflection for that.
Will spare you the calculation, because I have to find it out myself first.
But this all made me suspect that within a sertain range of outside temps,, and same speed, the heating up and cooling down of rubber is in balance so hottest part of rubber stays below 265 degr F.
You will understand that if outside temp is 265 degr F , the rubber can never cool down that much that it stay below 256 degr F, because temp differences are zero then .
Luckyly we dont drive at these extreme outside temps.
But mayby and outside temp of 110 to 120 still keeps the heating up and cooling down in balance ( because of the lesser deflection by the higher tirepressure) so rubbber stays below 265 degr.
And again if I determined this 265 degr F right to be the temp at wich hardening begins. - jadatisExplorerWhen 65 outside,a inside tiretemp would be expected of 110/115degr, when driving about 50/55 m/h.
Is 45/50 d temp-rising.
80/90>140=50/60 rising. So mayby a higher cold pressure would be advisable. - JimK-NYExplorer IIThanks,
I don't know about reaching 212 degrees, but I do know on a highway run during 80 or 90 degree weather, the psi on my tires will increase corresponding to a temp of a little over 140 degrees. - jadatisExplorerOnce had contact with someone o a valve importer in Holland ( where I live) And He gave documents about maximum pressures of valves given , where for cold of 18 degr C/65 degr F, and standards for higher pressure for warm above that max cold pressure the valves must stand . He also wrote me that the tire inside air can rise to boiling point of water even ( 100 degr C/212 degr F) , for instance by descending from mountains annd using the brakes to often.
Then the heat of brakes is transported by the rimms to the tire inside.
Once had me explained in a long telephone conversation with a man from Vredestein ( now part of Apollo) about tire pressure advice is for giving the rubber not higher temp then the point at wich to many sulfur bridges form. The rubber needs a sertain amount of sulfur bridges to make it flexible, so your nailprint wont keep standing in the rubber, but to many make it hard ireversible, and every next bending of it by the deflections , then tears the damaged structure a bit further until at a sertain moment blowing tire, or treath coming loose .
Mind that every segment of the tire deflects and flexes back about 10 times a second when driving about 50m/h. This produces heat, wich has to be cooled down, or better transported to the outside.
Dont know anymore if he also mentioned the 65 degr F , but combined it myself.
Some write its 20 degr C /68 degr F . but this 3 degr F would not give such a difference , so who cares who's exactly right.
And because for valves also 65 degr is used, I assume for tires too.
So no hard evidence but circumstantial.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
