- CapriRacerExplorer II
jkwilson wrote:
CapriRacer wrote:
jkwilson wrote:
CapriRacer wrote:
Just an FYI:
I just encountered a tire with a 3 digit plant code - first one I've seen. They have been permissible since April 2015 and will be mandatory starting April 2025.
I don't know of anywhere on the net where the 3 digit codes are published - yet!
Should be able to find it Here
Well, that doesn't help as the code is 1YC and it's on a private brand tire.
Came back to LLIT in Sriracha, Thailand from that page. Just put 1YC in the DOT Code box
Oops!
My bad! I didn't know you could do that. I've always used this for a forward lookup.
Thanks - jkwilsonExplorer III
CapriRacer wrote:
jkwilson wrote:
CapriRacer wrote:
Just an FYI:
Came back to LLIT in Sriracha, Thailand from that page. Just put 1YC in the DOT Code box - Joe_WayExplorer
CapriRacer wrote:
jkwilson wrote:
CapriRacer wrote:
Just an FYI:
Does this help? It's a list of two-digit codes, though, not three. 1Y is SHANDONG HUATAI TYRE CO., LTD.
PLANT CODES - CapriRacerExplorer II
jkwilson wrote:
CapriRacer wrote:
Just an FYI:
Well, that doesn't help as the code is 1YC and it's on a private brand tire. - jkwilsonExplorer III
CapriRacer wrote:
Just an FYI:
Should be able to find it Here - CapriRacerExplorer IIJust an FYI:
I don't know of anywhere on the net where the 3 digit codes are published - yet! - downtheroadExplorerGosh...just glancing at the origin cities on this list......LOTS of far away places with hard to pronounce names....
Just an observation. - MEXICOWANDERERExplorerKinda nice to peruse in advance, then check selected tires once at the tire dealer. Your link completes the missing info. Thank you senor jkwilson :)
- jkwilsonExplorer IIIIf you want to know where a particular tire was made Tire Plant Listing
