joshuajim wrote:
N-Trouble wrote:
Tom N wrote:
N-Trouble wrote:
You can use nitrogen in your tires if it makes you feel better as it is more stable than oxygen and will not raise the PSI as much as it heats.
Under equal pressures, all gases expand at the same rate. A gas expands by the same proportion as the temperature rises, provided external pressure remains the same.
True however nitrogen is a "dry" gas unlike oxygen which contains moisture, and as a result will not see as dramatic changes in PSI with temperature. This is one of the biggest reasons racers use nitrogen for consistent PSI across varying temps.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=191
Still not correct. ALL bottled gasses are dry whether they be nitrogen, oxygen, argon or just about anything else. Pure gasses by themselves DO NOT contain any moisture. AIR, which is mostly nitrogen/oxygen is what contains water vapor, and even that can be almost dry if run through a refrigerated air dryer.
OK but you knew what I meant... Air, not oxygen. Compressed air contains moisture. There ya happy...
