rfaulkner99's avatar
rfaulkner99
Tires not aligned when backing up
Hi, wondering if this is an issue or not. I have a 30' Cherokee Grey Wolf, and when I am backing in at an angle I have noticed that one of my wheels does toes out more than the other while turning, is that normal?
Looks something like this:
  • Its doing the same thing when going forward in a turn,.....literally trying to peel the tires off the rims :))
  • Anonymous's avatar
    Anonymous
    Approved
    MFL wrote:
    I try not to leave suspension/wheels twisted when backed in, parked. I will pull ahead/back a little to release the twist first.
    Jerry
    This! :)
  • I try not to leave suspension/wheels twisted when backed in, parked. I will pull ahead/back a little to release the twist first.
    Jerry
  • Yes - very common with solid axle trailer suspension systems and the equalizers used on them. As long as everything is aligned when you're driving forward in a straight line and you're not seeing abnormal tire wear, you're OK.
    Rob
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
