Thinking about buying a tpms 507rv. Tired of not knowing what is going on. Any comments on the 507 or any other model. I believe it is a good system but never used one? As always thanks for the great ...
Equalizers are basically two valve extender hoses connected to a single inflation point. The problem with having one sensor for two tires occurs when one tire fails and the equalizer's internal check valve isolates the remaining tire. The TPMS sensor still "sees" the pressure in the good tire, with no indication that the other one has failed. Crossfire at least, does offer an optional hose setup that allows individual sensors for each tire.
