โOct-13-2017 03:33 PM
โOct-16-2017 07:16 PM
llr wrote:
have someone apply the brake and watch the display while you wiggle pull and push every bit of wire from the TV to the drums that you can reach
โOct-16-2017 07:12 PM
arkie guide wrote:
Sounds like up and down when pulling causes the wire to ground out. Disconnect brake wire at first junction disconnect all the magnet's read wire to ground while shaking it to simulate moving. Then hook each magnet to direct from controller and check. A lot of trouble for sure - but do not put a price n safety.
โOct-16-2017 09:46 AM
โOct-16-2017 09:15 AM
โOct-14-2017 06:24 AM
Crabbypatty wrote:
As I learned even though the P3 is indicating a short, you still have brakes its just that one of the magnets, or wiring to it has an issue.
What an OP suggested to me and I did was jack up one wheel at a time and spin it, then have someone depress the brake, to locate the wheel. Once that is done and you find the wheel, check the wiring, looking for loose, worn rubbed. You can do a continuity check by connecting both sides to an ohm meter. I bought 50' roll of two conductor 16 gauge wire from the home center (lamp cord) and soldered on alligator clips. I stuck it in the appropriate hole on the 7 way plug then back to the wheel.
In my case the wires were fine, trailer ground was fine, and it turned out to be the magnet. The OP said if the wires are good just replace the magnet and that's what I did. Problem solved. I now always carry two sets of full brake assemblies with me as my brake problem occur hundreds of miles from home. I also carry wire. Never a good feeling being over the road with a problem. I hope that this helps you.
Happy trails
โOct-14-2017 04:03 AM
โOct-13-2017 08:05 PM
โOct-13-2017 07:49 PM
time2roll wrote:dryfly wrote:Were the magnets replaced?
Is it possible that the magnets could be breaking down internally under load of breaking??
โOct-13-2017 07:48 PM
babock wrote:
Magnets can fail and have internal shorts. You are going to have to disconnect one magnet at a time to determine which one is at fault.
In my trailer, if I ever have to do any brake wiring work, I will homerun every magnet to a common connection in a distribution box so that troubleshooting something like that is easier.
Use an ohmeter and measure between the brake terminal and ground of your trailer connector with it unplugged. Since magnets are typically a little over 3 ohms, you should measure slightly below 1 ohm for the 4 of them in parallel.
โOct-13-2017 07:43 PM
mapguy wrote:dryfly wrote:
The magnets should be fine with the miles indicated. Unless the assemblies were installed wrong...
Both controller messages are indicative of trailer side wiring issues. First place to start is the cross over wire inside the axle housing. These chafe and the insulation cracks causing both types of error.
Short error would be a cross connection on the brake positive and negative wires.
Overload could be multiple issues, but most common is brake positive contacting the axle housing.
Check any wire nuts and scotch lok wire connectors -they fail but look outwardly fine.
โOct-13-2017 05:46 PM
โOct-13-2017 05:24 PM
โOct-13-2017 05:08 PM
โOct-13-2017 04:16 PM
dryfly wrote:
Recently installed 4 new electric brake assemblies and Prodigy P3 controller. Worked great for 800 miles.
Plugged the trailer in one morning and got a "Short" error on the controller. Checked all truck/trailer wiring and nothing evident. Next time I plugged in trailer I got an "Overload" error. Prodigy tech support this does not indicate a short to ground but that the system is drawing too much current.
This has evolved into a highly intermittent issue with the brakes working about half the time and getting the "Overload" the other half. I have eliminated the truck and controller as being part of the problem.
Obviously it has to be wiring in trailer or brake magnets causing the problem. The error will not occur with the truck setting still, but it just doesn't react like a wiring issue, and should show up as a "short" error if it was wiring.
