cbwallace
Aug 18, 2019Explorer
Trailer brakes stop working when headlights are on
My Reflection has developed an issue where the trailer brakes stop working when my headlights are on. In the truck I get a Check Trailer Wiring message. When this occurs the trailer brakes don't work. When I turn the headlights off trailer brakes work again. On may last trip this also happened about 50% of the time I used a turn signal. I have checked 7-pin connector and find no corrosion. I am thinking it is a grounding issue but not sure what to check in the 5th wheel, any suggestions?
Chris
Chris
