starcraft69 wrote:
If i install a 3000 watt inverter to a transfer switch and I am running on the inverter power. Then go start my portable generator that the rv is plugged into. When it transfer to the generator power is there any loss of power? Can my TV and cable box be on and running? I was looking at the PowerMax PMTS-30 30 Amp Automatic Transfer Switch.
We use the Boondocker ATS-30 with no problem and they are silent because they use the DC coil relays. Several Inverters and generators and no problems. The Parallax units hummed and were noisy.
BD ATS-30
