alliemac9's avatar
alliemac9
Trimetric model to order? Leaning toward flush-mount...
I note there is a newer Trimetric (2030) which seems to not have the -A versus -RV designations of the 2025. In my mind, I was envisioning mounting this flush like the 2025-A model. The likely location for everything is in the entry way and we're tall - don't need any additional hazards for bumping into things.
Does anyone know if the ones that come with the enclosure for surface mounting can be flush mounted?
  • Thanks for the input! Found a 2030-A on Ebay from a reputable seller and ordered it.
  • If you want to flush mount it, get the flush mount version (it is available). When I did boat work before the depression, an owner bought a surface mount and wanted me to flush mount it. I did, but it was a bear to cut the hole.
    Matt
  • TriMetric TM-2030 is available in two models:TM-2030-RV and TM-2030-A. per the link below.
    Click Here
    I just received my surface mount unit from them.
    LeRoy
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
