landyacht318
Sep 25, 2015Explorer
Trojan t-1275 vs Signature series J150 RE
Before winter, I need to get a dedicated flooded house battery, my Northstar AGM-27 has been working hard as both house and engine battery for the last 4 months, and I want to return it to engine starting duty/emergency capacity duty.
The battery I have been desiring and planning on, is the Trojan T-1275.
Recently, I became aware of the J150 signature series which is marketed as a renewable energy battery.
The case size is the same, but for handle differences which make the J150 3/4" wider. I can fit either, but no taller. No t105's, no J185s. Only the T-1275 or the J150, or Smaller. I am not going for any smaller flooded 31 or 27 size ever again. They are rated for only half the cycles as the t1275 or j150.
The J150 weighs 2 Lbs more than the T-1275, at 84Lbs
The J150RE also states it has an Absorption voltage range of 14.1v to 14.7v
The T-1275 says absorption voltage is to be 14.8v. No range, just 14.8.
What are we to infer by this Wide absorption voltage range on the RE line?
I was hoping it would mean the battery would be happier on my low and slow 198 watts of low and slow solar, compared to the golf cart's, 10 to 13% 'recommended' charge rate.
If this were true, would it then protest being fed a 30 to 50% rate from my alternator? My vehicle also will allow upto 14.9v and this is hammered in stone, just as no more solar is possible on my roof.
T-1275 Spec sheet
Signature Series J150 Renewable Energy
The Non RE J150 is also 84 Lbs, 2 lbs more than the T-1275, but also states 14.8v Absorption voltage.
Trojan J150
So, is the RE battery just a different sticker and a lower ABSV to appeal to the renewable energy market?
Kind of like how Condorde markets Lifeline AGM and SunExtender AGM lines while the specs and PDFs would indicate they are the same exact battery?
I know a call or Email to Trojan is in order, but I was hoping for Some MexWanderer pontification on these ponderables.
T-1275 Spec sheet
Trojan J150
