3_tons's avatar
3_tons
Mar 26, 2019
Troubleshooting Compressor Windings
For those with the appropriate skill level, I found these two items of interest to help evaluate leaky or failed insulation on air conditioner compressor motor windings. Readings are taken across the three terminals which are, C=Common, S=Start, and R=Run. Before removing outside weather cover, first make certain that power is disconnected (and verify), then in the interest of meter accuracy, disconnect the wire leads from each terminal before taking readings.
Note that one of the three wires (Common) may connect to a round thermistor device (for over temp protection) which can fail and can be removed (lifts out) and replaced if necessary.
https://m.youtube.com/watch?v=1W08vFdhtLk
And:
https://m.youtube.com/watch?v=raG_N_hz6ng
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
