Freep
Jun 23, 2018Explorer
deltabravo wrote:
(A. Where did you put the inverter and why? )
A: Under the bathroom sink, because that's the only place it would fit and because it's very near the battery bank. Cables are less then 2 feet long
Thanks.
My battery compartment is under the bathroom sink. As I look at it, I realize that if I wire an inverter directly to the batteries I will be bypassing my battery bypass switch. So when I flip that switch I'll still have the inverter connected.
It looks like I'm probably going to have to mount the inverter to the underside of the kitchen counter.
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 15, 2025
