BB_TX
Dec 02, 2022Nomad
Do I understand right that you ran a hose from the antifreeze jug to the pump inlet connection? Assuming the pump is good that should work if you have a good tight hose connection at the pump. Slightest air leak will stop the pump from pulling liquid in.
Or buy an RV winterizing hand pump. Google it.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
