pawpaw47 wrote:
fj12ryder wrote:
I like my TST system but I don't like what I feel is an excessive time delay between when the monitor loses the signal from a sensor, and when the monitor notifies you that the signal has been lost. An hour is a long time to be without contact and not know it.
I had the same problem with mine, but I spoke with the techs at TST about it and they suggested installing their repeater. That totally fixed my issues. You may want to talk with them about it.
Happy travels!
I installed a remote antenna that I had left over from my Pressure Pro (big mistake replacing the Pressure Pro with the TST).
The antenna does not require a power source and can be installed anywhere. I mounted mine at the rear of the truck on the trailer hitch. Do not know if it has solved all of my problems as due to the one hour notification I could still have a system that is communicating erratically and if a signal makes at least once every 50 minutes I would never know I have an unreliable system.
