path1
Aug 08, 2019Explorer
myredracer wrote:path1 wrote:Dexter has the wire gauge table below. I didn't know it existed until someone posted in my earlier thread. I used automotive brake cable and the only place I could find #12 was at the local hitch shop. Not the most elegant method, but I tie wrapped it to the axle tubes and the propane pipe. The cable was way too large to pull into the axle tubes and I didn't want to pull down the coroplast. For splices, I soldered them and used shrink wrap and then tape over that. I also securely tie-wrapped the splices at the backing plates so they wouldn't get damaged from vibration. I'd rather see the backing plates designed so that the splices are inside the drum instead.
Thanks for posting. If I remember right you are into electric type stuff. For me elec sometimes a mystery. I'm going to do mine soon I hope. Your upgraded wire size, how did you determine the size? And what connections did you go with? (I was thinking of Soderling and shrink tube.
Thanks
Good info thanks
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 15, 2025
