Itinerant1
Dec 26, 2019Explorer
If it's the 4 little screws that loosen up inside which causes the cover plate not to hold parts in place just take a drop of loctite on the screws.
Use the blue grade... "Loctite Threadlocker Blue 242 is designed for the locking and sealing of threaded fasteners which require normal disassembly with standard hand tools. The product cures when confined in the absence of air between close fitting metal surfaces."
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
