EAKOCH's avatar
EAKOCH
turn signal problems
Hello, I have a 96 sea breeze motor home built on a ford f53 chassis 133, my problem is when I put on the turn signals only the tail lights(flashing) come on, the dash light arrows don't come on either. when I put on the emergence lights(four ways) only the front lights flash and now the dash light arrows flashing also. I have checked all the fuses that I know of and the flasher seems to be working fine. it has a 470 engine. If anyone can help me on this I would be very grateful. Thank you. eakoch@earthlink.net
  • RoyB's avatar
    RoyB
    My 99 JEEP had similar problems with the turn signals not working every time. I squirted WD40 into the contact area of the lever switch and worked it back and forth several times. Solved those probelms... I have to do this a couple times a years.
    Might gain a couple more years before you have to replace the whole unit...
    Roy Ken
  • I agree with John, it's likely the contacts in your multi-function (directional/hazard/wiper) switch have failed. Here's one source at Amazon, but there may be cheaper sources. Changing the switch is not particularly challenging if you pay attention to the details.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
