- joelcNomad
Cummins12V98 wrote:
Get a quality WATTS adjustable PR.
That's the brand I have. Good construction. - Cummins12V98Explorer IIIGet a quality WATTS adjustable PR.
- joelcNomadI am not sure what brand of regulator I have because I am out of state right now, but be sure you get an adjustable regulator with a gauge, not just one with a gauge that is preset.
- DFordExplorerX2 for using a pressure regulator! Many campgrounds use "city water" and their pressures can exceed 100psi which is a lot more than your water system is designed to handle.
The "Twinkle Star water pressure Regulator" Here's a link to a similar one that looks even better to me: https://www.amazon.com/Esright-Pressure-Regulator-Lead-Free-Adjustable/dp/B075RRCWGD/
I never had any luck with smaller and cheaper inline non-adjustable ones and have been using a whole house 3/4" Watts regulator adapted for male/female hose connections but the price for that is double what the one in the link is and there's no gauge. The gauge is not freeze proof and if you let it freeze the bourdon tube will be bent so that the gauge will no longer read correctly and there's no way to fix it. Once the pressure is set, there's no need for a gauge. Here's picture of the inside of a pressure gauge.
- Old-BiscuitExplorer IIIIF you are going to use the 'City Water' for source then by all means USE a water pressure regulator
You want one that has a decent flow rate and can control pressure....3 gpm minimum and 45-50#
I prefer a WATTS adjustable .....as it can be rebuilt if needed
I use it at spigot with a 'wye' to control water thru potable hose for refilling fresh water tank and thru the other non-potable hose for general service
I also exclusively use on-board pump since 2008 when had a major leak while sleeping using the pressure regulator, regulator controlled pressure to 50# but city water ran for HOURS flooding 5th wheel.
$6000 plus and 2 weeks of headaches (we were FTng at the time)
NOPE.....not again - DutchmenSportExplorerNot what your are asking about, but I don't use any water pressure regulators.
Many years ago, with our first travel trailer, we did an overnight at a KOA and the check-in manager recommended we use a pressure regulator because the campground pressure was 120 psi, which would blow out most RV plumbing. I thanked him for letting me know.
I thought about that setting up the campsite for the night and thought about that Cameo regulator the RV dealer gave us with the starter package. But I decided right then and there to never use a pressure regulator, or ever hook up to city water directly. From that point onward, we always filled our fresh water tank and used the on-board water pump. If we are at a campsite that has water on the site, I'll run the hose for convenience, but use it to fill the fresh tank only, then turn the water spigot completely off.
I figure, the on-board water pump, although it makes noise, will never exceed the RV's most extreme pressure possible. And I've never had problems with my water lines in over 20 years, 1 pup, 3 TT, and 1 5er later.
It's just a suggestion, something to think about. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
