dougrainer
Aug 30, 2018Nomad
1. The light stays ON because you are plugged into your 120 shore power. Disconnect the Shore Power and push STORE. The light should go OFF. If it does NOT, then the coach disconnect solenoid is bad(stuck)
2. Your refer does NOT use 10x more power. What makes you think this? Just turn the refer OFF, if you do not want it running.
3. A standard RV refer on 120 will pull 2.6 amps---310 watts AC power. Most residential's slightly less.
4. The Intellitec disconnect system you have uses "latching " solenoids. That means they use NO DC power to be engaged or disengaged. Doug
