TenOC
Sep 03, 2023Nomad
Unusual propane plumbing???
We have a 2014 3100RL Montana we bought it used on the non-door side the propane tanks are connected to the automatic crossover and what I will call a standard way, no problems.
However, on the door side connected to the propane tank is an in-line pressure gauge (no problem) then the flexible propane line is connected to a single pressure regulator (much like this one in the photo below) before connecting to the iron pipe which crosses over to the other side. I do not know why there is a pressure regulator on the door side. Your thoughts are welcome.
A problem that may or may not be related to this configuration. There appears to be a propane leak that we cannot find. When we open the propane valve on the tank on the door side as expected the pressure gauge shows full pressure. Then if we turn off the valve on this tank very slowly the gauge pressure drops to zero. We have use soapy water to check for leaks and cannot find any leaks. I do not smell any propane other than the normal smell that is usually associated around the tank after one fills the tank
![](https://i.imgur.com/N7ysg09l.png)
