garyemunson
Feb 26, 2019Explorer II
Update on Lippert slide mechanisms
When Lippert first came out with the in wall slide mechanisms, the failure rate was terribly high. How are people doing with them now? Our 2015 Winne has had only one issue but that was caused by poor installation and I was able to correct that before any damage was done. I see they now use a steel rack rather than the aluminum one. I can see on mine the aluminum is beginning to wear in the closed position no doubt from rough roads shaking the slide and putting strain on the aluminum teeth as they hold the slide in place against the steel spur gear. I'm sure this is why they changed to the steel rack. Older posts complain about motor/gearbox failures but that seems to have abated. I'm comparing the issue with a similar one I experienced in the elevator trade in the 80's when the old, reliable (and big) door operator motors started being replaced with small gear motors. For the first 5 years we could not get replacements fast enough and we all hated the new design. 40 years later, the tiny gearmotors have become as reliable as the older, "washing machine" type motors of the past. I appreciate the general physics of the Lippert style mechanisms as they secure the slide much better when stowed without the need for the broomsticks wedged at the top while travelling. I remember the first time we drove our previous Fleetwood without the broomsticks (with the old bottom mounted slide mechanism) and seeing the top of the slide wiggling in and out on a bad road. I make it a point to use the CRC PowerLube 2X a year on the Lipperts as recommended and they still work like new. We already have 50K on our coach so our slides have seen a lot of deploying and retracting. My main concern is the longevity of the gear motors. I'm hoping, like the elevator units I worked on, that technology has caught up with design and they will have a long lifespan. The work I had to do on it was amazingly simple. Access to them seems difficult at first glance but once you do it, it's far easier to get to them than the older slide drives. Anyone had problems with 2015 or later Lipperts and if so, what was the issue?
