Son_of_NorwayExplorerFeb 23, 2020UPS BatteriesAre UPS batteries good for use in RV's? (AGM Batteries designed for use in Uninterrupted Power Systems.) What are the advantages and disadvantages? Thanks for your advice.
poppaExplorerFeb 27, 2020i will be camping with and without but will have generator if shore power isnt available so 1 or 2 12v should work fine? thanks Gdetrailer
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
Related ContentBattery switch causing heat upDual battery set-up using chassis batteryBattery box filling up with water.Need help hooking up new 6V batteries!Gassing Up
