Butch50
Feb 12, 2018Explorer
I thought you were going to use your Ram. There is no way I would try it with the Samurai. The front end just doesn't have the capacity to handle that kind of weight on it. What is the GAWR on it and how much does the front axle weigh. You are already using up some the axle rating with the big tires and wheels unless you upgraded from the stock axles. Also what is the trailer weight and tongue weight?
