โMay-30-2019 09:04 AM
โMay-30-2019 01:18 PM
CA Traveler wrote:
Wondering about a wiring error even one battery reverse polarity. Remove component wiring and check everything for voltage and polarity. And if all OK have someone else check while you are not there to suggest anything. Sometimes we can't see the forest for the trees. Could also be equipment failure.
โMay-30-2019 01:17 PM
pianotuna wrote:
Set the width when posting to 375.
โMay-30-2019 01:15 PM
time2roll wrote:
I read the Victron website and the Lynx shunt is rated 1000 amps and the maximum fuse is 800 amps. Not sure you need the maximum fuse as 350 amps should be fine.
Question is where is that power going? What did you just turn on when the shunt fails?
Usually a shunt is to measure power in/out of the battery so the charging system does not over charge/discharge the battery. I assume the actual shunt is burned through right?
I have a 50Amp shunt (analog meter) and I know it will open like a fuse if there is a short.
Or is this just a communication issue as said by 2oldman?
โMay-30-2019 01:14 PM
โMay-30-2019 12:43 PM
pianotuna wrote:I thought 640 was the official max width.
โMay-30-2019 12:37 PM
โMay-30-2019 11:50 AM
GordonThree wrote:x2. Go 48!
With an impressive system like that, why 12 volts?
โMay-30-2019 11:21 AM
โMay-30-2019 11:20 AM
โMay-30-2019 11:08 AM
Mako Kupo wrote:Just quote my post to see the code. You just grab/paste the Url and hand-type the height parameter yourself. The original size of the picture matters not.
i looked and looked, i can never find the option for it. !
โMay-30-2019 10:32 AM
2oldman wrote:'Mako Kupo wrote:Just do it here.
u, i just put the image in microsoft paint and shrunk it there. ive never been able to easily get imgur to work after hundreds of times.
โMay-30-2019 10:23 AM
โMay-30-2019 10:20 AM
2oldman wrote:
You only need to specify width or height, not both.
โMay-30-2019 10:18 AM
โMay-30-2019 10:08 AM
