countrykids's avatar
countrykids
Victron smart shunt
I just installed a Victron smart shunt in our class c. I have two group 27 batteries so in setting up the device I entered 200 in battery capacity, 50% in discharge floor and enabled Soc alarm at 50%. Does this seem right?
    Nope.
    Group 27 sized RV/Marine "deep cell" batteries typically have a Ahr capacity of closer to 80 Ahr each perhaps a bit less. With 2 you have 160 Ahr max and at 50% about 80Ahr for the pair.
    Since these are in reality a "combo" start/deep cell, they do neither job well and also have a much shallower DOD if you really want the get the maximum rated discharge cycles.. Basically not much more than 20% of the capacity should be used if you care about getting the max life from them..
    I have a Victron smart shunt..Yes it sounds right if your batteries are really 100ah each..And as mentioned above,you can choose 50% or whatever for longevity..The secret is to get the true details of your battery to enter into the app for the most accurate results..Ballpark numbers will give you ballpark results..
  • Your realworld ah capacity will vary depending on your discharge style and the condition/care/age of your batteries.
    12.2v typically represents 50% SOC for a lead-acid battery. Me, I'd do a load test and see how many ah's it takes to get the voltage down to 12.2v. That's your discharge floor. Double that result for your realworld battery capacity.
