Oct-06-2022 02:40 PM
Jan-08-2023 11:02 AM
ThruTraffic wrote:
I'm done here. Thanks for all the reasonable suggestions. If I ever resolve it I'll come back and update this post.
Jan-07-2023 10:38 AM
Jan-07-2023 07:19 AM
ThruTraffic wrote:
Phoenix Cruiser 2551 30a service
- First noticed it when A/C turns on then stumbles. Voltage at another RV outlet dropped well below 100. Capacitors good. A/C working fine until this point. A/C did trip ITS 20a breaker one time. 30a main held.
- Problem persists when disconnected from shore power and generator running. Main indicator this is an RV wiring problem not shore power delivery system.
- Thermostat threw an E1.
- Inverter monitor behind driver seat threw an E2 and E5.
- Can turn on toaster at one outlet voltage drops 3v
- Can turn on hot water heater voltage drops 3v
- Hooked up a 15a draw elect device drops 5v
- System wide problem
- Checked connections at transfer switch, socket for shore power, junction where old EMS used to be, mains in RV breaker panel. Checked neutrals, grounds and feeds. All tight.
Shore power is my RV lot shop. I can find no voltage issues there even under load. Problem is on the load side of the RV sidewall shore power connector. Even tried different cables and installed a new 30a breaker.
Am I missing any 120v main connections in the RV not listed above?
I’m stumped.
Jan-07-2023 01:04 AM
Jan-06-2023 05:14 PM
wnjj wrote:Perfect. Now we need this information from the actual RV.
I measure 121V at the pedestal.
I measure 119V coming out of the transfer switch.
I measure 118V at the main breaker of the RV sub panel.
I measure 110V at the output of the breaker in the RV sub panel.
I measure 108V at the receptacle.
Jan-06-2023 03:22 PM
ThruTraffic wrote:
Does anyone actually think I've not been measuring voltage during every test or component replacement?
Jan-06-2023 02:54 PM
Jan-06-2023 02:07 PM
wnjj wrote:ThruTraffic wrote:wnjj wrote:
I think this was mentioned earlier but you need to put a decent load in the RV then measure the voltage at every possible place you can between the source and load. You’ve said the voltage is good at the pedestal and bad at the load. This means there is a resistive connection somewhere. While under load, measure the output side of the breaker the load is connected to in the RV panel. Then measure another one to eliminate the breaker and wiring to the load. Next move upstream to the feeder line, transfer switch, etc.
The problem will be between the last “good” voltage and first “bad” one.
25 amps good enough? Note my last big post. There's nothing left to test; it's all new.
Maybe I'm missing something but I saw a post with various voltage drops measured with increasing loads turned on but not one where you measured multiple places along the same circuit. Your last big post talks about replacing a bunch of stuff. Neither of those addresses my suggestion.
When you have a voltage drop between two end points, there has to be an explanation. If it's simply due to wire size/length it will continuously decrease along the way and as you say it will be normal.
If what you are experiencing is abnormal, there must be someplace causing the drop. Rather than guessing, you should measure the voltage along every specific place you can access between the supply and the load.
You're also a bit all over the place with changing shore power cords and pulling the meter when as you said, the same happens on the generator. So the problem either persists inside your RV, or it's not actually a problem at all and is normal.
Jan-06-2023 01:19 PM
Jan-06-2023 05:45 AM
ThruTraffic wrote:OK and in the first post was mentioned E1, E2, E5
See first and last big post.
Residential type 120/240v electrical systems don't give error codes.
Jan-06-2023 04:16 AM
joebedford wrote:
Talk about not reading posts ....
Jan-06-2023 12:35 AM
time2roll wrote:wnjj wrote:Yes keep poking around until most of the voltage drop is found. Should not take more than a few minutes once there is access. Tightening a connector is not proof that it is functioning... need to measure.
Hard to tell what the error codes are saying without the owner's manual.
Jan-06-2023 12:34 AM
Dusty R wrote:
Maybe try a heat sensor, and check the entire path that the current will flow.
Jan-06-2023 12:32 AM
