hedgehopper's avatar
hedgehopper
Warning: Flojet portable waste pump
After hooking up the electrical circuitry of our new pump, we tested it by turning on the switch for a few seconds. The pump ran for maybe a fraction of a second and died.
Thinking we had a poor connection somewhere, we tested all the circuitry. Still dead. Finally we tested the fuse. It was bad.
Then we noticed the “Impeller Release Feature” on the instruction sheet: “After long periods of non-use, a stuck impeller can be easily broken loose with a screwdriver inserted in the motor-shaft slot.”
After we inserted a new fuse and turned the shaft with a screwdriver, the pump came to life.
The lesson: Before trying to run the pump, turn the shaft with a screwdriver.
  • Here's ANOTHER WARNING to add to my initial warning: The way the pump fits into its carrying case, sooner or later the wires coming out of the pump will break off. I am going to cut away a little of the inside of the case where it contacts the wires so the wires don't bend every time the case is closed.
  • I have the portable Flojet, but have never used it. I have it just in case, but it has never been out of the case in 10 years.
  • wa8yxm's avatar
    wa8yxm
    Never did find that in ye olde manual,. figured it out but it took a few fuses.
  • Make sure you have the switch OFF when you use the Screwdriver. That sudden torque when it releases can hurt your wrist or fingers. A Stuck impellor means something not approved for a macerator tried to go thru the Impellor. Doug
  • I never had my Flojet jam after storage, but it doesn't like to be run dry - it'll slow down and blow the fuse.
  • eHoefler wrote:
    After use, i run oil through it to lubricate the impeller for storage
    Never mind.
  • After use, i run oil through it to lubricate the impeller for storage
  • WE just replaced our water pump with a Flojet works great so far. It is much quieter and does not pulsate. However I think the old, other brand pump, has been slowly failing and I did not realize it.
    i just had the Flojet on hand with the idea that I'd use it to pump water into the tanks when boondocking.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 17, 2025
