Does anyone know what brand water heater I would have in my 2010 Jayco 23FB? I would like to order an anode kit for it, but the trailer is put away and covered. Thanks
The Atwood unit should have a plastic drain plug approximately 7/8" the Suburban unit is around 1-1/16" and metal with the anode rod attached. Per Atwood at the rally you should never use the anode rod in their units, and use the plastic drain plug. Not a steel one.
