23hotrodr's avatar
23hotrodr
water heater flame fades out
We have an Atwood 10 gallon water heater with spark ignition. On this last trip, the water heater would light and then the flame would fluctuate a lot. Many times it would start out strong and then go down to nothing and the unit would attempt to relight. Sometimes this would be successful, and sometimes not.
All other gas appliances work properly-- stove, furnace, refrigerator. the gas valve assembly appears to have 2 gas valves and a small regulator . I suspect this gas valve assembly is faulty. I have confirmed proper gas flow to the valve.
Anyone else seen this problem? Any other ideas before I replace the gas valve assembly?
Thanks-- Mick
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
