drillagent's avatar
drillagent
Water heater INOP on electric
Noticed the other day that my Suburban 12 gal water heater was not heating on electric. Gas works fine. Replaced the element and it worked for about 10 min then quit. Any suggestions? Really don't want to call a repair guy if I don't have too.
  • Check wall plug also it could be loosing connection there. I had one that would do that but it should not do it setting still.
  • T-stats.......
    Under the cover above gas valve----Left Side 120VAC black wires
    High temp is top one.manual reset (trips at 180*F)
    Normal temp is bottom one (Opens at 130*F)
  • Interesting that it would work for 10 minutes on the new element and then stop again. How did the old element that you removed look? I would start by checking for continuity with a meter on the old element to see if it’s good or bad
  • Turn off the power and check all connections. A $10 voltmeter (used with safety kowledge) can establish voltage at the element wires. And a clampon ammeter can determine amps. It could also be other components that failed.
  • You need a multi-meter if you are going to do your own electrical work.
    Lacking that, "call a repair guy".
    Or pretend that it doesn't HAVE an electric option.
