I have a Suburban SW10DEL water heater and the igniter goes through its three cycles but no fire. I was wondering how you check the gas solenoid/valves. I think that one of them is bad.
A quick check,.... put a wrench on top of the gas valve coil when the ignitor is sparking. If it is energized, it will have a magnetic pull. Sure you have gas to it? Sometimes it takes a number of tries to get the line purged.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
