Old-Biscuit
Jul 19, 2016Explorer III
IF bypass was issue then you would get cold water flow out of hot water side of faucets
If water heater was still filling you would get spurts of air/water out of hot side of faucets
Check valve in water heater HOT out is clogged up.
It is a cheap plastic plunger/spring/o-ring assembly that easily fails/clogs
Especially when water in water heater is old rusty scaly water.
Drain and thoroughly flush water heater tank
Replace anode rod if you water heater is a SUBURBAN (Atwood doesn't use them)
Remove hot line fitting at water heater (check/clean inside of fitting)
Remove 'nipple' in hot out on WH Tank.....check valve is internal of nipple.
Replace with new check valve
